February 4, 2020 at 3:09 pm
fischr
SubscriberHello,
I added a material to the Engineering Data in Workbench R19. After solving with initial temperature value of 200°C i get the error message:
*** WARNING *** CP = 0.484 TIME= 15:21:05
Material property ALPX of material 1 is evaluated at a temperature of
0, which is below the supplied temperature range. Temperature range
checking terminates.
As you can see in the picture, I have defined the temperature range of the thermal expansion from 200 to 400 °C:
when i save the input file Workbench is sending to APDL you can see that the temperature range is missing. Afert mpdata,aplx there are no mptemp,1,200 and mptemp,2,400 commands:
/com,*********** Send Materials ***********
Temperature = 'TEMP' ! Temperature
MP,DENS,1,7.7e-09, ! tonne mm^-3
MPTEMP,,,,,,,,
MPTEMP,1,20
MPTEMP,2,200
MPTEMP,3,400
MPDATA,EX,1, ,200000,190000,170000, ! tonne s^-2 mm^-1
MPTEMP,,,,,,,,
MPTEMP,,,,,,,,
MPTEMP,1,20
MPTEMP,2,200
MPTEMP,3,400
MPDATA,NUXY,1, ,0.3,0.3,0.3,
MPTEMP,,,,,,,,
MPTEMP,,,,,,,,
MPTEMP,1,200
MPTEMP,2,400
MPDATA,KXX,1, ,18,21, ! tonne mm s^-3 C^-1
MPTEMP,,,,,,,,
MPTEMP,,,,,,,,
MPTEMP,1,200
MPTEMP,2,400
MPDATA,ALPX,1, ,1.17e-05,1.23e-05, ! C^-1
MPTEMP,,,,,,,,
MPAMOD,1,20, ! C
MP,C,1,460000000, ! mm^2 s^-2 C^-1
/wb,mat,end ! done sending materials
why is the definition of the temperature range missing in the input file, although it is defined in the engineering data ?
- The topic ‘Workbench sending wrong engineering data to APDL’ is closed to new replies.
5054
1764
1387
1248
