May 15, 2024 at 8:06 pm
SB
SubscriberHello:
Regarding meshing in Workbench, from the Solution>Worksheet, the element type information gives some surface and/or contact elements although those are nowhere used in the model. Even the element count from the Mesh Statistics does not include those surface and contact elements. But, the worksheet summary indicates a certain number of surface and contact elements.
Why does this happen?
Thank you.
May 16, 2024 at 12:31 pm
Gary_S
Ansys EmployeeHi
For example:Â
Some boundary conditions are appled internally by Constaint Equations usually in the form of MPC elements.Â
Weak Springs are appled by COMBIN elements.Â
May 17, 2024 at 2:22 pm
SB
SubscriberThank you for your reply.
As I understand, these additional elements (surface/contact/combination, etc.) are not used in the analysis to solve and compute the results. Is this correct?
- The topic ‘Workbench Meshing’ is closed to new replies.
5799
