September 9, 2024 at 8:00 am
leec36
SubscriberHello.
I am using Workbench 2024R2 student version to calculate force between two coils.
I set everything and clicked solve, but the below was shown unfortunately.
*** ERROR *** CP = 0.219 TIME= 09:52:38
The option of C on the MP command is either not available for this
version of Ansys or the appropriate product was not selected for this
session.
Contact your Ansys support person for more information.I searched previous questions and answers, so I removed all unnecessary matrial properties, but Workbench steal returns the error message.
I attched all the solution information below as an appendix for your information.
I need sombody's help.
Thank you
Appendix
Ansys Mechanical Enterprise Academic Student
| W E L C O M E T O T H E A N S Y S (R) P R O G R A M |
* ANSYS MAPDL 2024 R2 LEGAL NOTICES *
* Copyright 1971-2024 Ansys, Inc. All rights reserved. *
* Unauthorized use, distribution or duplication is *
* prohibited. *
* Ansys is a registered trademark of Ansys, Inc. or its *
* subsidiaries in the United States or other countries. *
* See the Ansys, Inc. online documentation or the Ansys, Inc. *
* documentation CD or online help for the complete Legal *
* Notice. *
* THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION *
* INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY *
* PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS. *
* The software products and documentation are furnished by *
* Ansys, Inc. or its subsidiaries under a software license *
* agreement that contains provisions concerning *
* non-disclosure, copying, length and nature of use, *
* compliance with exporting laws, warranties, disclaimers, *
* limitations of liability, and remedies, and other *
* provisions. The software products and documentation may be *
* used, disclosed, transferred, or copied only in accordance *
* with the terms and conditions of that software license *
* agreement. *
* Ansys, Inc. is a UL registered *
* ISO 9001:2015 company. *
* This product is subject to U.S. laws governing export and *
* re-export. *
* For U.S. Government users, except as specifically granted *
* by the Ansys, Inc. software license agreement, the use, *
* duplication, or disclosure by the United States Government *
* is subject to restrictions stated in the Ansys, Inc. *
* software license agreement and FAR 12.212 (for non-DOD *
* licenses). *
2024 R2
Point Releases and Patches installed:
Ansys Service Pack 2024 R2.16580608
Discovery 2024 R2.16580608
Core WB Files 2024 R2.16580608
Ansys Dynamic Reporting 2024 R2.16580608
SpaceClaim 2024 R2.16580608
CFX (includes CFD-Post) 2024 R2.16580608
Chemkin 2024 R2.16580608
EnSight 2024 R2.16580608
FENSAP-ICE 2024 R2.16580608
Fluent (includes CFD-Post) 2024 R2.16580608
Polyflow (includes CFD-Post) 2024 R2.16580608
Forte (includes EnSight) 2024 R2.16580608
TurboGrid 2024 R2.16580608
ACIS Geometry Interface 2024 R2.16580608
AutoCAD Geometry Interface 2024 R2.16580608
Catia, Version 4 Geometry Interface 2024 R2.16580608
Catia, Version 5 Geometry Interface 2024 R2.16580608
Catia, Version 6 Geometry Interface 2024 R2.16580608
Creo Elements/Direct Modeling Geometry Interface 2024 R2.16580608
Creo Parametric Geometry Interface 2024 R2.16580608
Inventor Geometry Interface 2024 R2.16580608
JTOpen Geometry Interface 2024 R2.16580608
NX Geometry Interface 2024 R2.16580608
Parasolid Geometry Interface 2024 R2.16580608
Solid Edge Geometry Interface 2024 R2.16580608
SOLIDWORKS Geometry Interface 2024 R2.16580608
Speos 2024 R2.16580608
Aqwa 2024 R2.16580608
Autodyn 2024 R2.16580608
Material Calibration App 2024 R2.16580608
Customization Files for User Programmable Features 2024 R2.16580608
Mechanical Products 2024 R2.16580608
Motion 2024 R2.16580608
Academic Student 2024 R2.16580608
***** MAPDL COMMAND LINE ARGUMENTS *****
BATCH MODE REQUESTED (-b) = NOLIST
INPUT FILE COPY MODE (-c) = COPY
SHARED MEMORY PARALLEL REQUESTED
SINGLE PROCESS WITH SINGLE THREAD REQUESTED
TOTAL OF 1 CORES REQUESTED
INPUT FILE NAME = C:\Users\user\AppData\Local\Temp\WB_user_5612_2\_ProjectScratch\Scr3306\dummy.dat
OUTPUT FILE NAME = C:\Users\user\AppData\Local\Temp\WB_user_5612_2\_ProjectScratch\Scr3306\solve.out
START-UP FILE MODE = NOREAD
STOP FILE MODE = NOREAD
RELEASE= 2024 R2 BUILD= 24.2 UP20240513 VERSION=WINDOWS x64
CURRENT JOBNAME=file 09:52:37 SEP 07, 2024 CP= 0.016
PARAMETER _DS_PROGRESS = 999.0000000
/INPUT FILE= ds.dat LINE= 0
DO NOT WRITE ELEMENT RESULTS INTO DATABASE
*GET _WALLSTRT FROM ACTI ITEM=TIME WALL VALUE= 9.87694444
TITLE=
wbnew--Magnetostatic (A5)
ACT Extensions:
LSDYNA, 2024.2
5f463412-bd3e-484b-87e7-cbc0a665e474, wbex
/COM, ANSYSMotion, 2024.2
20180725-3f81-49eb-9f31-41364844c769, wbex
SET PARAMETER DIMENSIONS ON _WB_PROJECTSCRATCH_DIR
TYPE=STRI DIMENSIONS= 248 1 1
PARAMETER _WB_PROJECTSCRATCH_DIR(1) = C:\Users\user\AppData\Local\Temp\WB_user_5612_2\_ProjectScratch\Scr3306\
SET PARAMETER DIMENSIONS ON _WB_SOLVERFILES_DIR
PARAMETER _WB_SOLVERFILES_DIR(1) = C:\Users\user\AppData\Local\Temp\WB_user_5612_2\wbnew_files\dp0\SYS\MECH\
SET PARAMETER DIMENSIONS ON _WB_USERFILES_DIR
PARAMETER _WB_USERFILES_DIR(1) = C:\Users\user\AppData\Local\Temp\WB_user_5612_2\wbnew_files\user_files\
--- Data in consistent MKS units. See Solving Units in the help system for more
MKS UNITS SPECIFIED FOR INTERNAL
LENGTH (l) = METER (M)
MASS (M) = KILOGRAM (KG)
TIME (t) = SECOND (SEC)
TEMPERATURE (T) = CELSIUS (C)
TOFFSET = 273.0
CHARGE (Q) = COULOMB
FORCE (f) = NEWTON (N) (KG-M/SEC2)
HEAT = JOULE (N-M)
PRESSURE = PASCAL (NEWTON/M**2)
ENERGY (W) = JOULE (N-M)
POWER (P) = WATT (N-M/SEC)
CURRENT (i) = AMPERE (COULOMBS/SEC)
CAPACITANCE (C) = FARAD
INDUCTANCE (L) = HENRY
MAGNETIC FLUX = WEBER
RESISTANCE (R) = OHM
ELECTRIC POTENTIAL = VOLT
INPUT UNITS ARE ALSO SET TO MKS
*** MAPDL - ENGINEERING ANALYSIS SYSTEM RELEASE 2024 R2 24.2 ***
01055371 VERSION=WINDOWS x64 09:52:37 SEP 07, 2024 CP= 0.078
***** MAPDL ANALYSIS DEFINITION (PREP7) *****
*********** Nodes for the whole assembly ***********
*********** Elements for Body 1 'COil_half-1\Solid' ***********
*********** Elements for Body 2 'COil_half-1\Solid' ***********
*********** Elements for Body 3 'COil_half-1\Solid' ***********
*********** Elements for Body 4 'COil_half-1\Solid' ***********
*********** Elements for Body 5 'air-1\Solid' ***********
*********** Send User Defined Coordinate System(s) ***********
*********** Set Reference Temperature ***********
*********** Send Materials ***********
session.
NUMBER OF WARNING MESSAGES ENCOUNTERED= 0
NUMBER OF ERROR MESSAGES ENCOUNTERED= 1
+--------------------- M A P D L S T A T I S T I C S ------------------------+
Release: 2024 R2 Build: 24.2 Update: UP20240513 Platform: WINDOWS x64
Date Run: 09/07/2024 Time: 09:52 Process ID: 7136
Operating System: Windows 10 (Build: 19044)
Processor Model: AMD Ryzen 7 3700X 8-Core Processor
Compiler: Intel(R) Fortran Compiler Classic Version 2021.9 (Build: 20230302)
Intel(R) C/C++ Compiler Classic Version 2021.9 (Build: 20230302)
AOCL-BLAS 4.2.1 Build 20240304
Number of machines requested : 1
Total number of cores available : 16
Number of physical cores available : 8
Number of processes requested : 1
Number of threads per process requested : 1
Total number of cores requested : 1 (Shared Memory Parallel)
GPU Acceleration: Not Requested
Job Name: file
Input File: dummy.dat
Working Directory: C:\Users\user\AppData\Local\Temp\WB_user_5612_2\_ProjectScratch\Scr3306
Total CPU time for main thread : 0.3 seconds
Total CPU time summed for all threads : 0.2 seconds
Elapsed time spent obtaining a license : 0.3 seconds
Elapsed time spent pre-processing model (/PREP7) : 0.0 seconds
Elapsed time spent solution - preprocessing : 0.0 seconds
Elapsed time spent computing solution : 0.0 seconds
Elapsed time spent solution - postprocessing : 0.0 seconds
Elapsed time spent post-processing model (/POST1) : 0.0 seconds
Sum of disk space used on all processes : 0.0 MB
Sum of memory used on all processes : 29.0 MB
Sum of memory allocated on all processes : 2304.0 MB
Physical memory available : 16 GB
Total amount of I/O written to disk : 0.0 GB
Total amount of I/O read from disk : 0.0 GB
+------------------ E N D M A P D L S T A T I S T I C S -------------------+
| RUN COMPLETED |
| Ansys MAPDL 2024 R2 Build 24.2 UP20240513 WINDOWS x64 |
| Database Requested(-db) 1024 MB Scratch Memory Requested 1024 MB |
| Maximum Database Used 22 MB Maximum Scratch Memory Used 7 MB |
| CP Time (sec) = 0.219 Time = 09:52:38 |
| Elapsed Time (sec) = 2.000 Date = 09/07/2024 |
September 9, 2024 at 8:11 am
ErKo
Ansys EmployeeHi
Do you have shared topology (resulting in connected mesh between parts) for all bodies?
make sure you have that.
Secondly:
Please go to Engineering Data and select a material (air and any other used) and turn off "filter engineering data" - this filter button is shown in link below Please delete Specific heat, thermal conductivity and viscosity and all other properties that are not electromagnetic related and are thermal say related.
Go to Project schematic and "refresh" the project. You should be able to solve now.https://innovationspace.ansys.com/forum/forums/topic/no-s-n-curve/
All the best
Erik
5984
1307
