Workbench Job script on HPC
    • s_safiza
      I am trying to write a job script to submit my simulation on our university's cluster. We don't have an RSM license so we should generate our own job script and submit it on a Linux system. My simulation is on Workbench and the job script that I have generated is below:
      The problem I have is that I am requesting more than 8 cores from the cluster but Ansys only uses 2 cores! I need to add a command to ask Workbench to use the requested cores and memory from the cluster. I know for Ansys mechanical the command is "-np" but for Workbench, it is not defined. I would appreciate it if anyone knows what command should I add to use the requested resources from the cluster.
      Thanks in advance.
    • erik.kostson
      Hi
      First of all try to get RSM as this is the easiest way – talk to your University , but I do not think there is not a licence (RSM), and a cost for that as far as I know
      Not that straight forward. You need to supply a script (.py) in the batch line using the -R argument:
      runwb2 -B -F “D:\\OTHER\\sunbatch\\test.wbpj” -R ” D:\\OTHER\\sunbatch\\test.py”
      The test.py can include the settings as :
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/act_script/SolveProcessSettings.html
      config2 = ExtAPI.Application.SolveConfigurations["My Computer, Background"]
      x = config2.Default
      y = config2.Settings.License
      z = config2.SolveProcessSettings.ManualSolverMemorySettings.Workspace
      config2.SolveProcessSettings.ManualLinuxSettings.UserName = "jane.doe"
      config2.SolveProcessSettings.MaxNumberOfCores = 12
      See here for more info:
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/act_script/SolveProcessSettings.html
      All the best
      Erik
    • s_safiza
      Thank you for replying. Honestly, I tried to make a .py file including the script as it was mentioned in Ansys help as the link you sent me. But still, the analysis is done with only 2 cores. I included the screenshots below.
      Would you please let me know if you have any suggestions? Thanks a lot.
      Kind regards,
  • The topic ‘Workbench Job script on HPC’ is closed to new replies.
