June 9, 2021 at 3:35 pm
hani.sadek_i
SubscriberHello,
I am trying to open an old work bench file but it is not opening and it shows the bellow error
How can I solve that problem ?
I currently have ansys 2021R1, and that file was prepared using 2018 (I don't know if this is related to the current error)
June 14, 2021 at 2:09 pmNKC
You can try the following.
Rename the file you want to open with a shorter name.
Move the files you want to open a few folders above. It looks like the file location path is too long.
Regards Navya
June 16, 2021 at 8:04 pmhani.sadek_i
SubscriberThank you !
March 29, 2023 at 3:36 amLiam Flint
SubscriberHello, are you fix this?Â
LongPathTool is the most user-friendly solution for resolving issues with long paths file on Windows and Mac.ÂViewing 3 reply threads- The topic ‘Workbench File Opening Error’ is closed to new replies.
5094
1829
1387
1248
