Ansys Products
Ansys Products
Workbench 18.2 exception after install: Could not load file or assembly “IronPython”..
    • dukof
       Installed from file download ANSYSACADEMICSTUDENT_182_WINX64.zip
      SpaceClaim starts and works ok.
      Starting Workbench 18.2 either from shortcut or from SpaceClaim produces the following popup exception, and no workbench opening.
      How to proceed?
    • Raef.Kobeissi
      Hello What do you mean you started Workbench from SpaceClaim?
      What’s your PC specs and your Operating system?
      Cheers
    • dukof
      SpaceClaim has a Workbench tab with start workbench 18.2 button. But it's the same issue regardless where I start from or whether SpaceClaim runs or not. It first happened from Workbench 18.2 shortcut ("C:Program FilesANSYS Studentv182FrameworkbinWin64runwb2.exe"), before I ever had opened SpaceClaim.
      PC is Thinkpad W520 i7-2760QM, Nvidia Quadro 1000M, 16gb ram, SSD, Windows 7 Pro. Docked with 2 external monitors.
      Btw, I have IronPython at  "C:Program Files (x86)IronPython 2.7ipy.exe"
    • dukof
      Well I installed IronPython 2.7.5, and now Workbench does start.
  • The topic ‘Workbench 18.2 exception after install: Could not load file or assembly “IronPython”..’ is closed to new replies.
