Withdraw test
    • Ken Ng
      I am trying to make a simulation to match the experimental result with some data from another program
      This is my model, a 4.5 × 50 mm screw (modelled as smooth surface) inserted into a predrilled orthotropic block is the hole diameter slightly smaller than the screw's diameter (overlapping diameter from another program's data is 1mm) to create the friction contract (the blue part is the surface of the hole, the red part is the surface of the screw).
      The table is the orthotropic block material:
      Density (kg/m3)
      500
      Young's Modulus X direction (MPa)
      14700
      Young's Modulus Y direction (MPa)
      737
      Young's Modulus Z direction (MPa)
      1000
      Poisson's Ratio XY
      0.449
      Poisson's Ratio YZ
      0.292
      Poisson's Ratio XZ
      0.374
      Shear Modulus XY (MPa)
      1150
      Shear Modulus YZ (MPa)
      942
      Shear Modulus XZ (MPa)
      103
      The following are the screw material changed properties, other properties remain unchanged of the default structure steel material
      Density (kg/m3)
      8000
      Young's Modulus (MPa)
      200000
      Yield strength (MPa)
      215
      Ultimate strength (MPa)
      450
      Poisson's Ratio
      0.29
      The graph of force reaction for the displacement vs the displacement is plotted to do the comparison.
      the frictional contact is set as mu = 0.3 and with the command
      et ,cid, 174
      RMODIF,cid,21, 5.3
      RMODIF,cid,22, 4
      but I am encountering some problems:
      1. I wonder why the simulation failed to run the overlapping diameter is 1mm.
      When I set the hole diameter is 3.5mm (overlapping diameter is 1mm), the simulation goes error and gives me these messages. Why would this happen?
      2.  The DC coefficient failed to function or function weirdly
      So as the 1mm overlapping diameter can't work, I changed the overlapping diameter to a smaller value. but the DC coefficient would either cause errors like that shown in the previous image or give out a strange result that does not decay exponentially. What do I miss for the dynamic friction formula to work properly?
      3. How to insert the Hashin failure criterion into the model?
      I have checked this post (/forum/forums/topic/hashin-failure-results/) and the guide but I am still confused about where and how to input the Hashin failure criterion into the material. These are the data I have for the Hashin failure criterion
      Failure criteria:
      Parallel tension = 108 MPa
      Parallel compression = 29.8 MPa
      Matrix tension = 2.3 MPa
      Matrix compression = 5.5 MPa
      Longitudinal shear = 7.8 MPa
      Transverse shear  = 7.8 MPa
      Fracture energy
      Longitudinal tension = 1.6 N/mm
      Longitudinal compression = 60 N/mm
      Transverse tension = 0.06 N/mm
      Transverse compression = 0.2 N/mm
      Thanks
    • Ashish Khemka
      The error message indicates rigid body motion. What if you perform a modal analysis and see if any of the part seem to be unconstrained?
      Ashish Khemka
  • The topic ‘Withdraw test’ is closed to new replies.
