May 3, 2019 at 3:31 am
veera
Subscriberhi gd mrn to allÂ
i am trying to calculate the cl and cd values of wing in ansys fluent , in that reference value setup in fluent for 3d wing , what value i have to give ?, i watched some you tube videos , some one telling for calculating the cl and cd that reference value we have to get from report>projected area ,Â
but some one using face area from wing ( calculated in geometry design modeler) , some one using surface area of the wingbut i need to know clearly , which area suppose using in reference area , its should match with experimental calculations
May 3, 2019 at 11:06 am
Forum ModeratorIt depends on what reference you're comparing with from the experiment. I'd recommend looking at the ANSYS tutorials (under Documentation). You can always get the forces and figure it out from there?Â
May 3, 2019 at 11:19 am
Keyur Kanade
Ansys Employeecheck this one
https://confluence.cornell.edu/display/SIMULATION/FLUENT+-+3D+Transonic+Flow+Over+a+Wing
May 6, 2019 at 5:08 am
veera
check this one
 thank u mr. kkanade ..i learned lot from this videos..but still i have doubt in that one , for monitoring wing cl and cd why they selected wing tip aong with wing surface?
May 13, 2019 at 10:48 am
veera
SubscriberHI , I was noticed one thing (https://confluence.cornell.edu/display/SIMULATION/FLUENT+-+3D+Transonic+Flow+Over+a+Wing)Â in that they put wing surface are in that reference value to get the solution , but my case suppose i am putting planform area of the wing , then only i am getting results which is closer to the experimental
May 13, 2019 at 11:12 am
Forum ModeratorCan you provide some images (inline) along with areas. As you're looking at coefficients you need to be careful you're comparing like-for-like values, especially with experimental data where we don't necessarily know the reference area/force/whatever.Â
May 14, 2019 at 9:45 am
May 14, 2019 at 2:07 pm
Forum ModeratorSo, which reference area is correct if you look in the documentation & check against how the experimental data was calculated?
May 27, 2019 at 3:00 pm
veera
Subscriberhalf of the above wing area , 0.4
- The topic ‘wing cl and cd’ is closed to new replies.
3832
1414
1193
1100
1015
