TAGGED: airfoil, dynamic-mesh, poor-quality-elements, turbine-blade
July 23, 2021 at 2:00 am
ashwin_ev
SubscriberJuly 29, 2021 at 1:16 pmKarthik Remella
AdministratorHello Most of the issues you are referring to - Convergence, Dynamic mesh failure, are related to having a poor starting mesh. Your diagnosis seems correct - you need to improve your overall mesh quality.
To do that, there are a couple of things you can do:
Decompose your geometry into smaller parts
Add local mesh sizing in areas where there are small faces, edges, high curvatures etc.
Fine-tune your global mesh settings to get a reasonable mesh.
I vaguely remember that there was a Sim Cafe by Cornell University on Simulation of a Wind Turbine Blade. You could google this and see if this acts as an appropriate starting point for your analysis.
Thank you.
Karthik
Viewing 1 reply thread- The topic ‘WIND TURBINE DESIGN ISSUES’ is closed to new replies.
Innovation SpaceTrending discussions- Project lines/edges into a face with the direction normal to the face
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
Top Contributors-
4512
1494
1386
1209
