September 16, 2022 at 8:54 pm
Melanie Butts
SubscriberI need to know whether to use a laminar or turbulent viscosity model, and if I need a turbulent one, which one to pick.
I am simulating the flow created by a 5 bladed room fan. We already took measurements of the air velocity created by the actual fan using an anemometer. We are not sure what the best effective viscosity settings are though, because we are not certain whether our flow is laminar or turbulent. Here is what we have so far.
Using a slow motion setting on a camera, the rpm was measured/counted to vary between 1033 and 1380 rpm. The fan geometry we are using in our simulation is shown below.Â
- Width of tips of fan blades (w) - 0.076 m
- Circumference of fan (c) - 1.1 m.
- Kinematic viscosity of air (k) - 0.00001506 m^2/s.
- Based on the rpm and circumference, I calculated the tips of the fan blades to be moving at 19 to 20.9 m/s (v)
- I estimated the Reynolds number using w*v/k
- Re ranged from 96,000 to 128,000
What would the critical Reynolds number be for a situation like this?
September 19, 2022 at 4:23 am
Keyur Kanade
Ansys EmployeePlease check following.Â
Laminar or turbulent flow? (ansys.com)
Keyur
September 21, 2022 at 9:00 am
ehsan.sadeghi
Subscribera simplest way would be measuring the flow rate in a fan rpm, then based on fan diameter and estimated mass flow rate you can calulate the reynolds number. it should give you a rough estimate of the flow regime.Â
September 24, 2022 at 11:17 pm
Melanie Butts
SubscriberThank you for your responses.
Keyur Kanade I looked at the link, and it deals with critical Reynolds numbers for internal flow. I should probably clarify that my box domain has pressure boundary conditions on all sides, and no walls. For this situation I would need to use a different critical Reynolds number than can be used for pipe flow, correct?
Thank you
September 24, 2022 at 11:29 pm
Melanie Butts
SubscriberEhsan Sadeghi I'm not quite sure what you mean. Are you suggesting than in the equation to calculate the Reynolds number
(v x L x rho)/(mu)
that I take my average axial velocity as v and my diameter as L?
Also, do you have any suggestions for what the critical Reynolds number or transition range would be, given this is external flow?
Thank you
September 26, 2022 at 8:23 am
ehsan.sadeghi
SubscriberExactly.Â
For external flat plate flow you may choose 3e5 as a critical transition Re number. In general there is no universal Re number that could define flow regime for all flows.
September 27, 2022 at 2:44 am
- The topic ‘Will the flow from a room fan be laminar or turbulent?’ is closed to new replies.
