October 17, 2019 at 4:01 pm
roytorc
SubscriberHi,
I am modelling the turbulent non-premixed flame touching the adiabatic surface (by set heat flux of the wall =0 in thermal boundary condition). However, there is a temperature gradient near the wall which I don't understand how is that possible. I've checked the heat flux across the boundary and it is 0. Please advise.
October 17, 2019 at 5:59 pm
Amine Ben Hadj Ali
Ansys EmployeeCheck temperature of the wall and near wall cell temperature -
October 17, 2019 at 6:27 pm
roytorc
SubscriberAfter checked, the values are:
wall --> Contour level 6, value in [820.98102, 907.81116].
near wall cell --> Contour level 10, value in [1168.3018, 1255.1318].
I still don't understand why there is the temperature gradient. Please help advise.
October 18, 2019 at 4:42 am
Amine Ben Hadj Ali
Ansys EmployeeNo on the wall check the wall temperature then on the same wall the cell temperature. -
October 18, 2019 at 3:09 pm
October 18, 2019 at 3:19 pm
Amine Ben Hadj Ali
Ansys EmployeeThat is not ideal so. You need to quantify it in better way. Either you use UDF or plot along the line wall and static temperature. -
Amine Ben Hadj Ali
Ansys EmployeeOr look after the gradients which you enable under solve set expert. -
October 18, 2019 at 3:21 pm
October 18, 2019 at 5:36 pm
Amine Ben Hadj Ali
Ansys EmployeeKeep temporary... to yes to see gradients for Post processing
Viewing 8 reply threads
- The topic ‘Why there is temperature gradient near adiabatic wall boundary condition?’ is closed to new replies.
1530
1386
1210
