July 26, 2021 at 6:21 pm
wmmhls
SubscriberMy simulation results aren't converging. Instead of that, some residuals are increased and reach infinity. And also, the results which I got with less number of iterations are unbelievable. what could be the problem for this..? How can I solve this..?
I'm simulating an air body in a 3x3x3 meter room with 9 vortex diffusers by using fluent (cfd). Purpose of this is to get the idea of the behavior of the air body which come through the diffuser and the air velocity in the duct (diameter is 150mm) is 1m/s. The system is at room temperature and all the other conditions are kept as defaults.
July 27, 2021 at 8:52 amAmine Ben Hadj Ali
Ansys EmployeeOkay: and your case is about? What shall we now provide as hints if you are not describing things like models used and mesh quality? I see you are using VOF: Why?
Viewing 1 reply thread- The topic ‘Why results don’t get converged and getting unbeleivable results and how to solve that?’ is closed to new replies.
Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
Top Contributors-
4507
1494
1386
1209
