September 23, 2022 at 6:33 am
lancer
SubscriberHi,
I'm currently doing simulation using a SOFC with Unresolved Electrolyte and I got the tutorial including the mesh file for a tubular design. I run it using the ANSYS 2021 R2, and it work perfectly fine. I tried to emitate it using ANSYS 2021 R1 following exactly all the step and also include some which are pre-defined at ANSYS 2021 R2 but not in 2021 R1. But, it said floating exception at R1 but not in R2. I followed it exactly, and input the same in R2 but it didn't work. Does it have something to do with the product or something or missing file ? I don't know
September 27, 2022 at 1:39 am
lancer
SubscriberThe only difference is the Flux type where in 2021 R2 you can set it as Rhie-Chow: Distance based while in 2021 R1 cannot. Does this help?Â
- The topic ‘Why my simulation run on ANSYS 2021 R2 but doesn’t run on ANSYS 2021 R1?’ is closed to new replies.
5899
1306
