FAQ Structural Mechanics – Imported
FAQ Import area. This is where our raw imported FAQ’s are imported to prior to editing and posting.
Why might assembly level cut operations performed in a CAD program appear to transfer the complete u
    • pgl
      The import of assembly level operations are not supported by most CAD Readers. If the import of assembly level operations are desired, consider using the respective CAD plug in geometry interface. Another alternative may be to export the CAD geometry to a neutral format, then import into Mechanical.
Viewing 0 reply threads
  • The topic ‘Why might assembly level cut operations performed in a CAD program appear to transfer the complete u’ is closed to new replies.
