October 25, 2021 at 8:25 pm
miratip
SubscriberI am setting up a simulation of a falling water droplet and air and attempting to run the simulation in batch mode via a journal file. The process I am using is to define the VOF multiphase model, add the second phase (water), define a cell register containing the cells in the droplet, initialize, and then patch the volume fraction to the cell register. For some reason the patch is not happening, although the commands get through the patch menu with no errors. When I run the same patch command in the Fluent TUI, it works with no problems. Also, when I run the patch command to patch the entire domain in batch mode that works. So it seems specifically like an issue with patching a cell register in batch command. Any ideas why this is happening?
October 26, 2021 at 9:19 amRob
Forum ModeratorIf you open the file that's failed in batch does the cell register exist? For batch runs it's often safer to initialise all cases and save their data files. The batch run then simplifies to reading in the case & data and running some iterations/time steps. Writing long batch journals can be more efficient but also adds in a risk of something not working.
October 26, 2021 at 4:35 pmmiratip
SubscriberYes, when I open the file, the cell register exists. My journal file has a list cell registers command which lists the droplet register. I can try reading in a case and data file with the setup and just running via the journal file. Is there a way to initialize and patch and then read that info into the journal file? Right now I am only reading in a case file.
October 26, 2021 at 10:56 pmai0013
SubscriberDouble check and navigate through TUI commands, step-by-step and try to find the error. I attach an extract of a journal file that I once employed to patch pressure for two cell-registers during a batch run. It worked fine for me.
;READ-CASE
file/read-case "myFluentCase.cas"
;INITIALIZE_FLOW
solve/initialize/compute-defaults all-zones
solve/initialize/set-defaults pressure 101325
solve/initialize/initialize-flow
;PATCH CANISTER AND SPHERE AT PRESCRIBED PRESSURES
;cylinder for FLUID_CANISTER
adapt/mark-inout-cylinder yes no 0.20500 0.20500 -0.094500 -0.015130 0.06495190 0.20242480 0.040
solve/patch () 0 () pressure 21e5
;sphere for FLUID_SPHERE
adapt/mark-inout-sphere yes no 0 0.126389 0 0.168389
solve/patch () 1 () pressure 4e4
October 27, 2021 at 10:20 amRob
Forum ModeratorThanks Just a note, always use / at the start of the command, ie
/adapt/mark-inout-cylinder yes no 0.20500 0.20500 -0.094500 -0.015130 0.06495190 0.20242480 0.040
To force Fluent to use the full command path from the root menu. Otherwise if the command is triggered from /display it'll fail as it's looking for "adapt" in the display menu tree.
October 27, 2021 at 11:56 amai0013
SubscriberThank you for the clarification ! I'll consider it for future reference
October 28, 2021 at 7:23 pmmiratip
SubscriberThanks y'all! The adapt/mark-inout-sphere command ended up working for me. I was previously defining the cell register in a different way that worked for me in the TUI but was not working in batch.
October 29, 2021 at 5:58 amDrAmine
Ansys EmployeeAlways better to use the search command helper in Fluent and write journal while trying TUI commands.
Viewing 7 reply threads- The topic ‘Why isn’t patch working in batch mode (Fluent)’ is closed to new replies.
5664
1890
1419
1304
