October 23, 2018 at 2:15 pm
October 23, 2018 at 2:32 pm
Keyur Kanade
Ansys EmployeeHi,Â
Can you please point out the crack. Can you please insert image of mesh.
Do you see same when you use serial mode?
Keyur
October 23, 2018 at 2:57 pm
October 23, 2018 at 3:02 pm
karthik.remella
AdministratorHello,
Based on the image you shared and if you are referring to these lines (screenshot attached), these, I think, are created by the mesh decomposition because of your parallel settings. If they appear of your mesh as well, as pointed out by Keyur, you can be sure that they are because of parallel runs.Â
Regarding convergence, please elaborate a bit more about your problem. Please share the necessary screenshots of your geometry, mesh, and boundary condition in a separate post.
Thank you.
Best Regards,
Karthik
- The topic ‘Why is there a crack on my fluent simulated cloud image, does it affect convergence?’ is closed to new replies.
