December 31, 2021 at 12:26 pm
Yahia_Alhaj
SubscriberHi everyone,
I'm doing a 2D analysis on the hull of a boat by using a VOF solver (Multiphase).
I will first share with you what I did exactly, then I will share the weird result I got :(
So starting with the mesh:
December 31, 2021 at 12:31 pmRob
Forum ModeratorLooking at the model I'd say it's not well converged, so check the time step. Otherwise it's doing what you told it to: at the inlet speed it's pushing water over the fixed obstacle. In reality the boat will (probably) rise with the water and sit at a different position.
January 1, 2022 at 9:31 amYahia_Alhaj
SubscriberI'm not solving a transient case
January 4, 2022 at 4:59 pmRob
Forum ModeratorSo it's not well converged and steady state. The result looks plausible given the set up. In 2d why would the water go under the obstacle rather than over?
Viewing 3 reply threads- The topic ‘Why is the VOF solver is not working properly? I got weird results’ is closed to new replies.
4939
1639
1386
1242
