Why is the flow result of the porous media model incorrect?
    • h395523899
      My model is a simple rectangular parallelepiped medium
      10*10*50 mm
      Permeability 1 D
      Entrance pressure 1000000 pa.
      Export pressure 0 pa
      Water density 1000 kg/m3
      Viscosity 1 mpa.s
      If calculated using the permeability formula
      The flow rate Q should be (1*9.869*1)/(1*5)=1.9738 cm3/s=1.9738*10^-6 m3/s
    • h395523899
      Formula calculation results are different from simulation results
      Is this because of the error generated by the simulation?
      Or is there a problem with the parameters I set?
    • DrAmine
      The formula is neglecting convective and diffusion transport but though the results are not far from one another. You can try if physical velocity would enhance the run.
  • The topic ‘Why is the flow result of the porous media model incorrect?’ is closed to new replies.
