February 16, 2023 at 7:56 am
February 16, 2023 at 1:49 pm
Govindan Nagappan
Ansys EmployeeHistogram appears similar between the two. You can click on the bar to see the elements with that quality range. See if that looks similar or see if you can spot the difference.
Also details on Mesh should list the min quality. See how that compares
It is possible that there is a sudden jump in mesh size that could cause lower quality. You can reduce the growth rate to improve mesh quality
- The topic ‘why element quality decrease after applying sphere of influence’ is closed to new replies.
1885
1404
1303
