May 4, 2024 at 6:29 pm
Ivosp
SubscriberI'd like to simulate the inflow/flow around a box. The fluid (air) itself is separated into 2 fluid bodies due to simulations planned for later. The inner body is a sphere, the outer is a cuboid.
 My setup:
Meshing
- Box as dead
- Inverse Quality: Max = 0.78 (only a few), Average = 0.02
- round about 2000000 cells
- I've already connected the congruent spherical surfaces of the 2 fluid bodies in the geometry (in SpaceClaim) and it's therefore treated as one (in simulation as interface). Therefore I used a conformal mesh.
- There is one velocity inlet (left side of the outer fluid body) and one pressure outlet (right side of the outer fluid body). All the other zones are walls.
- I answered the following questions as:
- Geometry Type -> The geometry consists of both fluid and solid regions and/or voids
- Change all fluid-fluid boundary types from 'wall' to 'internal'? -> Yes
- Do you need to apply Share Topology? -> No (Since the 2 spherical surfaces are already treated as one due to the settings in SpaceClaim)
- Enable Multizone Meshing? -> No
- Will you cap openings and extract fluid regions? -> No
- I used a poly-hexcore mesh
Solution
- velocity inlet = 13 m/s
- I left the rest of the settings as defaultÂ
- The congruent spherical surfaces, let's say I name them zone1 (from outer fluid body body1) and zone2 (from inner fluid body body2), are listed as Internal under Boundary Conditions as follows:
- zone1-zone2-body1-body2
- interior--body1
- interior--body2
- The hybrid initialization was done after 10 iterations (with 7.3e-09)
- For my first attempt, I set the number of iterations to 1000.
- I clicked on Check Case... and it said No recommendations to make at this time.
But after 1000 iterations the scaled residuals are still too high . The whole problem seems not that complex to me, but I am still a beginner and I have absolutely no idea what could be the reason for this. Can anyone help me?
The scaled residuals stayed like this even after 1000 iterations...Â
May 4, 2024 at 6:43 pm
May 7, 2024 at 1:34 pm
Forum ModeratorPlot contours of velocity around every 5 iterations for 50 iterations and look carefully at the output. Or put a couple of point monitors for velocity in the wake region. I suspect you've found a transient in the flow field from the way the residuals look, the monitors and contours will provide evidence of that.Â
- The topic ‘Why don’t the residuals converge?’ is closed to new replies.
6730
1319
1047
