August 27, 2022 at 5:33 pm
thaipham0815
SubscriberI am told that this should converge, but not told how to fix it nor can I find a solution online.
Here is the setup that I used in Ansys.
Solver: Transient, Pressure Based
Number of Time Steps: 6000
Time Step Size: 0.1
Max Iterations/Time Steps: 20
Fluid material: Water-Liquid
Method: Simple
Initialization: Hybrid
Mesh cell size: 0.001m
Nodes: 280521
Elements: 279017
Boundary Conditions:
Inlet velocity = 0.0115 m/s
Wall = No Slip
Outlet Gauge Pressure = 0 Pa
Thanks for the help guys!
August 29, 2022 at 1:03 pm
Nikhil N
SubscriberHello,
Can you extend the run for some more iterations? Also, can you post a snap of the residual plot here?
If it didn't work out, try reducing the time step size. Any specific reason for solving it with transient consideration?Nikhil
August 30, 2022 at 4:05 pm
Forum ModeratorIs this 2d?
- The topic ‘Why does the velocity in the center of the tank not converge?’ is closed to new replies.
- affinity not set
3977
1461
1272
1124
