August 4, 2025 at 11:15 pm
Shyam Prasad V Atri
SubscriberI have a tank which has these dimensions
x [-0.7,0.7]
y[-0.5 0.5]
z[-0.5 0.5]
I am trying to run the simulation with 4gpu and i keep getting error in the simulation. This error is so generic and i dont know why it is causing
Error:QSocketNotifier: Can only be used with threads started with QThread
I have given the correct gpu slicing --multi-gpu-slicing-direction=X but still i get this error
Can anyone suggest why?
August 7, 2025 at 11:08 am
Lucas Bertollo Baggio
Ansys EmployeeHello,
does it work for single GPU?
August 7, 2025 at 11:10 am
Shyam Prasad V Atri
SubscriberIt works for single gpu and two GPU the moment I request 3 GPU or 4gpu the simulation keeps erroring outÂ
August 7, 2025 at 11:25 am
Ansys EmployeeRocky works for single-node only. Are all your GPUs in the same node?
August 7, 2025 at 11:26 am
Shyam Prasad V Atri
SubscriberYes they are all on same node and same hostÂ
August 7, 2025 at 11:30 am
Shyam Prasad V Atri
SubscriberAll 4gpus on same node and one computer. Still it errors outÂ
August 7, 2025 at 12:54 pm
Ansys EmployeeWould you give me more deatails about your case?
August 7, 2025 at 1:01 pm
Shyam Prasad V Atri
SubscriberIts a mixing tank of 1m diameter and 1m height. There is a top inlet pipe of 20cm and bottom outet pipe of 20cm in the x direction hence the total distance covered in x direction ranges from negative 0.7m to positive 0.7m. the pipe diameter is 10cm. I have about 700 sphero cylinder particles made of multiple elements (flexible one)
August 7, 2025 at 3:17 pm
Ansys EmployeeWhat GPUs are you using? Do you have license for using 4 GPUs?Â
It also seems like you have very few particles for using 4 GPUs.Â
August 7, 2025 at 4:34 pm
Shyam Prasad V Atri
SubscriberÂ
I gave 700 as an example… I have 70000 particles I want to add more than that too… I am using L40s or H100 or a100 gpu of University hpc cluster. I believe the universitys acadamic ansys license should allow the use of four gpus. i did not see any restrictionsÂ
August 8, 2025 at 3:48 pm
Shyam Prasad V Atri
SubscriberHello Lucas, Any idea why such a simulation is not working. Please let me know.
August 11, 2025 at 1:24 pm
Ansys EmployeeTry to execute the simulation directly from RockySolver.exe (from ANSYS Inc\v__\rocky\bin), so you might get some extra information about why this is not working.Â
August 11, 2025 at 2:37 pm
Shyam Prasad V Atri
SubscriberÂ
So do you mean that i should try to run the simulation on GUI insted of script? (I am trying to run on HPC, not a normal computer)
August 11, 2025 at 2:59 pm
August 11, 2025 at 3:06 pm
Shyam Prasad V Atri
SubscriberI thought memory might be an issue and tried to allocate more memory but it still gives me the same error
August 11, 2025 at 5:26 pm
Ansys EmployeeWhich Rocky version are you using?
August 11, 2025 at 5:42 pm
Shyam Prasad V Atri
SubscriberRocky 2025 r1 (2025.0 academic university version)
August 11, 2025 at 7:38 pm
Ansys EmployeeCould you try to reproduce it in Rocky 2025 R2?
August 11, 2025 at 7:50 pm
Shyam Prasad V Atri
Subscriberi need to ask for the installation on hpc which may take time. is there any way this version can be used? Because changing versions is a time-consuming and painful process.Â
August 12, 2025 at 6:21 pm
Ansys EmployeeWe had a bug with multi GPU that was fixed in 2025 R2. I think that updating Rocky is your best first try!
August 14, 2025 at 6:14 pm
Shyam Prasad V Atri
SubscriberHey we are not able to get the installation file for hpc can you please tell us where can we get the installation file from for installing ansys 2025 r2 on hpc
3792
1388
1188
1095
1015
