Why does modal analysis repeat each natural frequency?
    • Amirmkr
      The following macro is for a cantilever beam and I was wondering why the frequencies are repeated in the results?
      /PREP7
      ET,1,BEAM188
      MPTEMP,,,,,,,,
      MPTEMP,1,0
      MPDATA,EX,1,,2.068e11
      MPDATA,PRXY,1,,0.3
      MPTEMP,,,,,,,,
      MPTEMP,1,0
      MPDATA,DENS,1,,7830
      SECTYPE,  1, BEAM, RECT, Beam01, 0
      SECOFFSET, CENT
      SECDATA,0.01,0.01,2,2,0,0,0,0,0,0,0,0
      K,1,0,0,0,
      K,2,1,0,0,
      LSTR,    1,    2
      LESIZE,ALL, , ,8, ,1, , ,1,
      LMESH,    1
      FINISH
      /SOL
      ANTYPE,2
      MODOPT,LANB,8
      EQSLV,SPAR
      MXPAND,8, , ,0
      LUMPM,0
      PSTRES,0
      MODOPT,LANB,8,0,0, ,OFF
      FLST,2,1,1,ORDE,1
      FITEM,2,1
      /GO
      D,P51X, , , , , ,ALL, , , , ,
      /STATUS,SOLU
      SOLVE
      The results are as follows:
       ***** INDEX OF DATA SETS ON RESULTS FILE *****
        SET  TIME/FREQ  LOAD STEP  SUBSTEP CUMULATIVE
         1 8.3119       1     1     1
         2 8.3119       1     2     2
         3 53.804       1     3     3
         4 53.804       1     4     4
         5 160.84       1     5     5
         6 160.84       1     6     6
         7 349.86       1     7     7
         8 349.86       1     8     8
      When a structure has symmetry, the the vibration in the X direction will have the same frequency as that in the Y direction (assuming symmetry in the XY plane). This is true for all modes that exhibit symmetry.
    • hollow4444
      Hey was hunting for a solution for this. I have a fixed hanging bar 1m long and 500sqmm cross sec area. When I do a modal analysis IÔÇÖm getting 1st and 2nd frequency as 18 and 3rd and 4th Frequency as 116.
      any idea how I can remove the repeats?
      thanks
      Remove them from what? Why do you need to remove them? Why is it not sufficient to simply ignore the repeats? What is wrong with leaving them in the solution results?
    • hollow4444
      Hey peteroznewman.
      I have been asked to provide the first 4 natural frequencies and compare it with analytical finite element method. so in the analytical Method i get the Following:
      F1:18.611, f2:116.638, f3: 326.59123, f4: 639.988
      so im worried My Modal analysis is missing something. Excuse the ignorance as i have just started this course.
      thanks
      In ANSYS, request 12 frequencies. Delete the duplicates and keep the lowest four.
Viewing 5 reply threads
  • The topic ‘Why does modal analysis repeat each natural frequency?’ is closed to new replies.
