Why does ansys repeat natural frequencies?
    • hollow4444
      Hey was hunting for a solution for this. I have a fixed hanging bar 1m long and 500sqmm cross sec area. When I do a modal analysis I’m getting 1st and 2nd frequency as 18 and 3rd and 4th Frequency as 116.
      any idea how I can remove the repeats?
      thanks
    • Vigneswaran Sridharan
      Hi Both effective mass and participation factor are parameters that help the user to get an answer for questions like:
      How many modes to extract?
      Which modes are contributing to the problem?
      Why do natural frequencies repeat in modal analysis?
      I will recommend you to watch the course on Modal analysis available atModal Analysis | Ansys Innovation Courses.
      This course has all the important background information for Modal analysis.
      Vigneswaran
    • hollow4444
      Hey Vigneshwar Would you be able to assist with a quick fix?
      Im doing this assessemnt due tomorrow evening and was wondering if i could fix it relatively quickly.
      I have taken 1) 4 Nodes and recieved the same repeats.
      2) i took 6 Nodes and still received the same repeats.
      I need to compare the First 4 Natural frequencies with Ansys and analytical method.
      Using analytical method(Roarks Formula) i get the first 4 Frequencies as :
  • The topic ‘Why does ansys repeat natural frequencies?’ is closed to new replies.
