January 25, 2021 at 5:31 pm
aprlina
SubscriberI am simulating entrained flow gasification and would like to use .RGP files for material property data as specified in Fluent User's Guide Section 8.16.6: Using Real Gas Property Tables.
January 26, 2021 at 3:25 pmRahul Kumar
Ansys EmployeeHello, n The error usually originates because of improper component naming. Please be sure to enter in the Details of material the Component Name exactly as it appears in the header of the RGP file. nJanuary 29, 2021 at 2:34 amluzechao
SubscriberWhat rahkumar said was WRONG. You had this issue because you didn't enable the beta features in Fluent.nFebruary 3, 2021 at 6:11 pmaprlina
SubscriberWhat rahkumar said was WRONG. You had this issue because you didn't enable the beta features in Fluent./forum/discussion/comment/104758#Comment_104758
Luzechao,nThank you so much for your suggestion! This was the exact problem. After enabling beta features through the TUI the RGP tables were recognized right away!nViewing 3 reply threads- The topic ‘Why does ANSYS Fluent fail to recognize my .RGP files?’ is closed to new replies.
Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
4042
1461
