October 17, 2021 at 8:16 pm
mark.hardiman
SubscriberHi,
New Ansys user here but I have lots of experience with writing my own FE code and other software.
I am running a simple model with just 3 truss elements to compare with my hand calculations. I am using linear elements and all three elements connect in a triangle so I have 3 elements and 3 nodes as illustrated here
October 17, 2021 at 9:31 pmBenjaminStarling
The "preview" of the elements is the same as the cross section you have defined. If it is bigger than you expect, you should check your units and cross section definition.
There are three nodes for linear line elements in Ansys. The third node is used to define the orientation of the cross section. Quadratic line elements therefore have 4 nodes. The extra node takes no extra part in the solution.
Under the solution folder there is an option "Beam Section Results". Set this to "Yes". This is just an ease of life feature, if you have mixed element types in a large model, results on beams can be annoying and get in the way. They are also not very accurate with regard to strain and stress.
October 17, 2021 at 10:30 pmmark.hardiman
SubscriberThanks Benjamin. Completely understood now. Much appreciated!
Viewing 2 reply threads- The topic ‘Why do the mesh stats show 6 nodes here instead of 3? (Truss Elements)’ is closed to new replies.
4858
1587
1386
1242
