April 11, 2024 at 7:34 am
kalindusalith115
SubscriberHi guys,
Recently I have done a simulations for converging nozzle with an inlet absolute pressure of 8 bar and the outlet is expanded to the atmospheric conditions. Theoretically, we know that the Converging nozzle cannot go beyond Mach 01, but in this simulation, it shows 1.6 Mach at the throat area the 1.04 Mach number at the exit as well.
To ensure that there is no area ratio at the straight part, I have designed the model using solid works( Previously done with a design modeler as well). The Mesh of the model has an aspect ratio of less than 3 as well as an orthogonal quality of more than 0.94.
Are there any errors in a method that I have used or any theoretical errors?
Please help
April 11, 2024 at 9:49 am
Forum ModeratorReplot with node values off in the contour. It may be a smoothing issue if the shock is very sharp.Â
- The topic ‘Why converging nozzle get Mach over 01’ is closed to new replies.
