February 28, 2017 at 9:12 am
Nikita
Ansys EmployeeI'm having trouble moving the body in ANSYS SpaceClaim?
September 29, 2017 at 11:51 pm
pgl
Ansys EmployeePlease check if you have applied any Assembly constraints under Design Tab on your Components in ANSYS SpaceClaim. If there are any Assembly Constraints like Align, Rigid,Tangent, etc, it may restrict the movement of the parts depending on the applied constraint. To move the Component using Move command, you will have to remove the Assembly constraint accordingly.
- The topic ‘Why can’t the body be moved in SpaceClaim?’ is closed to new replies.
