March 25, 2025 at 5:10 am
March 25, 2025 at 11:02 am
Forum ModeratorHow thick is the film?Â
March 26, 2025 at 4:42 am
2627971244
Subscriberoh it is 20 µm
March 26, 2025 at 8:38 am
NickFL
SubscriberI am not sure exactly what you are trying to accomplish here, but I will say that SpaceClaim, like most CAD software, does not really like those thin dimensions. Under such circumstances I typically create the model 1000x bigger than it needs to be (so mm become m and µm become mm). After bringing into Fluent, I then simply scale the model down to the appropriate size. (I won't lie, sometimes I forget to scale and the results are utter ridiculous. Doh!)
March 26, 2025 at 8:46 am
2627971244
Subscriberyes maybe you are right bro,i want to do a Hydrostatic bearings,so thin oil film is necessary,The size that is too large does not match the reality lol,maybe i can do it by other methods.
March 26, 2025 at 8:57 am
NickFL
SubscriberYes you would create your mesh in the larger scale, and then scale it in Fluent. This can be done using the Task Page->Scale... (where you check the mesh and stuff) or via the TUI, for example: /mesh/scale 0.001 0.001 0.001 where 0.001 is used to scale it from meters back into mm.Â
March 31, 2025 at 2:26 am
2627971244
SubscriberI tried it, but it's still the case. The model is still too thin, maybe I should try using Meshing.
March 31, 2025 at 7:35 am
NickFL
SubscriberAre you trying to create the mesh in SpaceClaim? If so, yes I would agree you would have much better control in ANSYS Meshing.Â
To Rob's point down below, what are the goals of your simulation. Your mesh might end up being very large. Will you have the computing capacity to solve such a problem. What are the quanitites of interest? Can a 2D model be utilized?Â
April 3, 2025 at 2:52 am
2627971244
Subscriberoh sorry my friend,i missed it,iam useing Meshing now,I want to divide the grid into different regions so that the grids in other areas are not very small,2-D is not ok,I have a small workstation,so i think it is ok.
March 26, 2025 at 9:23 am
Forum ModeratorAnother consideration will be mesh count. If you want to resolve the oil film you need to mesh to that scale too: 20microns is towards the lower end of what's sensible and means you're going to have cells at 1-2micron scale. Can you afford that level of refinement?Â
March 31, 2025 at 2:22 am
2627971244
SubscriberI want to complete this model by partitioning the grid into different regions. If the whole world has such small-scale grids, my computer will not be able to handle it.
March 31, 2025 at 9:23 am
Forum ModeratorWhich comes back to what you actually need the film layer for.Â
April 1, 2025 at 3:13 am
2627971244
Subscriberyes lol,thanks for your reply.
4628
1535
1386
1215
