August 10, 2023 at 3:59 pm
Ben_Ben
SubscriberI noticed I was getting no stress results for my simulation with Beams.Â
Here is my sim. I am displacing the top node and constraining the bottom. Here are start and end states:Â
But I get no stresses in my results.Â
So I checked the "beam section results" box:
I checked the D3 files and changed beam to 1 for *DATABASE_EXTENT_BINARY, *DATABASE_BINARY_D3PLOT and *DATABASE_BINARY_INTFOR:
I also saw this link: https://lsdyna.ansys.com/beam/
So I used elform = 1 for beam formulation
I get this error if I run in Ansys LS-Dyna (via Mechnical in Workbench) and on HPC:Â
August 11, 2023 at 2:16 pm
Jim Day
Ansys EmployeeTry setting BEAMIP to the total number of integration points for your beam cross-section. That number should be evident from looking at the variable QR in *SECTION_BEAM. For example, QR=2 (default) provides 4 integration points so BEAMIP should be set to 4 in that case. -
August 11, 2023 at 3:52 pm
August 11, 2023 at 4:01 pm
August 11, 2023 at 4:10 pm
Jim Day
Ansys EmployeeIf you change QR to 2, also change CST to 0. You'll then be modeling a square cross-section with dimensions 1.0x1.0 and 2x2 integration. Set BEAMIP=4. Do you get then get beam stresses in the 4 integration points? -
August 11, 2023 at 4:15 pm
Ben_Ben
SubscriberMy beam is a circular cross section. I can try the above though.
August 11, 2023 at 4:19 pm
Jim Day
Ansys EmployeeFor circular, leave QR=2, set CST=1, and set TS1=TS2 to the outside diameter and TT1=TT2=0. -
August 11, 2023 at 4:22 pm
Jim Day
Ansys EmployeeIf you successfully get beam stresses in the modified model, we can go back and try to address the case of using a user-integration rule (*INTEGRATION_BEAM). -
August 13, 2023 at 9:15 pm
August 14, 2023 at 4:04 pm
Jim Day
Ansys EmployeeI think this would be easy to debug if I had your input file, but unfortunately, we're not allowed to share files via the Learning Forum. See the notes in https://www.dynasupport.com/howtos/element/beam go into more depth than I have. See especially the last two paragraphs in those notes. -
August 15, 2023 at 4:27 pm
Ben_Ben
SubscriberÂ
Maybe I’m missing something. I’ve had another run through and I can’t seem to find the issue. Quite confused because is a really simple model, one beam being displaced at one end and held at the other. I’ve attached a couple screenshots of the input file. Included all the relevant parts apart from the nodal and element data. Can you spot anything?Â
August 15, 2023 at 6:00 pm
Jim Day
Ansys EmployeeThe issue could be the way in which you're postprocessing the d3plot data. As a check, add *DATABASE_ELOUT and *DATABASE_HISTORY_BEAM so as to output beam data to the output file elout. Then try plotting axial stresses at beam integration points by reading elout into LS-PrePost using Post>ASCII>elout>Load. I'm assuming you're running SMP for this small model. Also, while debugging, I'd get rid of *DAMPING_GLOBAL and also set BEAM to the default value of 0 in *DATABASE_EXTENT_BINARY. -
August 18, 2023 at 3:17 pm
August 18, 2023 at 3:30 pm
Jim Day
Ansys EmployeeLeave BEAMIP set to 4. Rerun. Postprocess elout with LS-PrePost to get axial stress or just open elout with a text editor to check for stresses. I'm assuming you're running SMP LS-DYNA and elout is written as an ASCII file. -
August 18, 2023 at 3:33 pm
August 18, 2023 at 3:47 pm
Jim Day
Ansys EmployeeGreat. That was just a check to make sure beam stresses were being output. You should be able to get the stresses from d3plot as well. When you postprocess d3plot with LS-PrePost, make sure you've selected "Beam" if creating fringe plots or "Etype: Beams" if plotting time histories. -
August 18, 2023 at 4:13 pm
Ben_Ben
SubscriberAmazing, is working with fringe plots and plotting time histories.Â
Is still not working in Workbench LS-Dyna. But know I know how to access via LS-PrePost its ok.Â
Thanks for your help!
- The topic ‘Why am I getting no stress results for my beams?’ is closed to new replies.
5969
1307
