July 22, 2021 at 8:25 pm
RRaghavendra
SubscriberHello,
I am working on mass transfer in air-water bubble columns in ANSYS Fluent, using the Eulerian multiphase model. For computing the mass transfer coefficient, I am creating a UDF. In the UDF, I need to get the volume fraction of air in a cell, for computing the specific interfacial area. Which macro should I use for this? There are macros for getting the values of flow variables, but I don't know what it is for phase volume fraction. Please do help me with this.
Thanking you in advance,
Raghavendra.
July 23, 2021 at 6:27 amDrAmine
Ansys EmployeeAll of these macros are standard cell data access macros and documented in the customization manual: 3.2.3.12. VOF Multiphase Model Macro.
July 23, 2021 at 6:41 amRRaghavendra
I did find a macro called C_VOF in the section you mentioned. But it seems that C_VOF can be used only for the VOF multiphase model. I want to find the phase volume fraction in a cell for the Eulerian model. This is the reason I posted here earlier.
Thanking You Raghavendra.
July 23, 2021 at 10:51 amDrAmine
Ansys EmployeeThe same macro can be used for all Eulerian Based Multiphase Approaches in Fluent: So that is the right macro!
July 23, 2021 at 10:53 amRob
Forum ModeratorJuly 23, 2021 at 11:23 amRRaghavendra
I am being asked to login when I click on the link you sent. I don't have an account and when I try to create one, I am not able to, since I have the student version of ANSYS Fluent. Please provide the same information by some other means so that I can access it.
July 23, 2021 at 12:24 pmJuly 23, 2021 at 1:02 pmRRaghavendra
Thank you for helping me with the link issue. In the link you provided, there is a macro for the volume fraction of the ith size bin, which is in context of population balance modelling. My query is related to the Eulerian model.
July 23, 2021 at 1:26 pmRob
Forum ModeratorWhich model do we use for PBM work?
July 23, 2021 at 3:26 pmRRaghavendra
SubscriberI agree that Eulerian model is used with PBM, but I am working with just the Eulerian model, without PBM, assuming a constant bubble size. The solution previously suggested can be used when PBM is used with the Eulerian model....not for the case with just the Eulerian model.
July 23, 2021 at 3:55 pmRob
Forum ModeratorAnd it's used here https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/flu_udf/flu_udf_sec_define_source.html%23flu_udf_udf_degas We're only able to guide using what's in the documentation where UDFs are concerned. Have a look at the multiphase specific macros and see how they're used as all then have examples.
July 23, 2021 at 3:57 pmRRaghavendra
SubscriberThank You. I will look into it.
Viewing 11 reply threads- The topic ‘Which macro must be used for getting the phase volume fraction in an Eulerian multiphase model?’ is closed to new replies.
5969
1307
