November 25, 2020 at 8:57 am
omkarmadhekar
SubscriberNovember 25, 2020 at 9:00 amKeyur Kanade
Ansys EmployeeThis is layer compression due to proximity. nPlease change gap factor in inflation controls. Please change it to 0.25 and check. nPlease see help manual for more details about these commands. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnnNovember 25, 2020 at 9:10 amomkarmadhekar
SubscriberBut which is the best method to to do inflation correctly? on that part nNovember 25, 2020 at 9:39 amNovember 25, 2020 at 10:22 amRob
Forum ModeratorThey're all best depending on what you need. I tend to prefer smooth transition as the jump in cell size is lowest, but I don't deal with high speed flow so am less worried about first cell height. I also regularly run with 2-3 layers of inflation, or none at all as the high aspect ratio cell isn't suitably for my application. The meshing rules are really guidelines and there's a lot more to it than y+ and cell skew. nViewing 4 reply threads- The topic ‘which is the best inflation opption smooth transition total thickness or the first layer thickness?’ is closed to new replies.
