July 2, 2021 at 9:04 am
solani
SubscriberHello eveybody
Because of changing geometries in my simulation I need to use the VFOPT command but I am not sure where to put this command. Can anyone help?
Here is my code so far:
SF,InnerInsulationSurface, rdsf,0.9,1 ! radiation settings SPCTEMP, 1, 22 ! ambient temperature in case enclosure is open stef,5.67e-8Â ! stefan boltzman constant toffst,273.15Â ! temperature offset VFOPT, new !forcing new calculation of few factors hemiopt,10 ! resolution of view factor calculation tunif,22 ! initial temperature
Thank you for your help
Ani
July 2, 2021 at 9:13 amErKo
Ansys EmployeeHi
You would need to add an apdl command object under the thermal solution and use it for all load steps:
See here for some info:
Thank you
Erik
July 2, 2021 at 9:22 amsolani
SubscriberThank you Erik for your very very fast reply. I selected the wanted step for my APDL command. But now I am a bit confused: What are load steps? Equals the number of load steps to the number of Number of Steps that you can control in the Analysis Settings?
However what I wanted to ask in my post is the following: Does it matter where I put the VROPT command? So like this
stef,5.67e-8! stefan boltzman constant
toffst,273.15! temperature offset
or like this
I know from Python or Java that the place in the code matters. I thought it would be the same for Ansys. Therefore my question is where to put the VFOPT command in the code.
Thank you again in advance.
Viewing 2 reply threads- The topic ‘Where to put VFOPT command’ is closed to new replies.
5794
