December 14, 2023 at 4:04 am
Yash Kathar
Subscriberi want to find alternating curves and cycles values to carryout fatigue test for assembly including materials like carbon fibre,hdpe,carbon steel, abs,where could i get the data from..please suggest resourses... thank you.
December 14, 2023 at 1:29 pm
danielshaw
Ansys EmployeeWe do not have access to that type of test data. You can search the internet, but the best option is probably contact the material supplier. The compnay that supplies those materials should be able to provide their material properties.
December 22, 2023 at 8:12 pm
David Mercier
Ansys EmployeeHi, here a discussion where it is explained where to find SN Curves in Ansys Granta products:
/forum/forums/topic/sn-curve-for-cast-steel-and-gray-cast-iron/
Once you have found the material you want for your simulation, you can use export functions (and then generate material inputs file) or directly use Granta Selector for example inside Ansys Workbench. Up to you.
December 22, 2023 at 8:37 pm
danielshaw
Ansys Employeeyes, you can search the Granta database for your material.
- The topic ‘where to find SN curve data for materials those are not available in ansys wb’ is closed to new replies.
4597
1495
1386
1209
