Ansys Products
Ansys Products
Where is Energico now?
    • uddin43
      Hi, In the previous versions of Ansys 19, there is a module named Energico, primarily used for generating equivalent reactor networks (ERN). I can not see Energico in 2024 version. How can I generate the same ERN now? Please help
    • Harshvardhan
      As of 2023 R2, Ansys has ended support of Energico. If you require continued use of Energico and are not able to use a previously released version, please create a support request for the technical support team.
      Regarding ERN, Chemkin might help you out there. Be sure to check out the following links:
      1.2. Overview of the Chemkin Software (ansys.com)
      1. New Features and Enhancements (ansys.com)
      I hope this helps. Other members of forum can also chime in with their helpful insights.
      Harshvardhan
