Ansys Products
Ansys Products
When Will ANSYS Workbench Be Scaled to Support 4K Monitors?
    • Jee Loong Hee
      Dear ANSYS,
      I found the icons or fonts on the drop down tree of the Workbench to be extremely small, could you advise me when will ANSYS developer improve this? And is this matter currently being look after by the team?
      Thank you.
      Yours Sincerely,
      Jee Loong
    • George Karnos
      There is discussion, but nothing to report yet.
      You can try these workarounds to help with the Display of ANSYS Programs:
      Automatic scaling and graphics window interactivity may not work correctly for 4K monitors by default.
      You can set the QT_AUTO_SCREEN_SCALE_FACTOR System Environment Variable equal to 0 to restore auto-scaling and graphics window functionality
      Please try the Windows System Variable listed above and let me know if this resolves the problem.
      ALSO:
      1.Change the High DPI settings under compatibility settings. " Properties of workbench > Compatibility > Click on Override high DPI scaling "
      2. Change the "Scaling performed by" option to "System(Enhanced)"
  • The topic ‘When Will ANSYS Workbench Be Scaled to Support 4K Monitors?’ is closed to new replies.
