July 3, 2024 at 6:02 am
Eunchong
SubscriberHello,Â
I'm tryting to run a Chemkin oppdiff simulaiton usnig CMD prompt
During the pre-processing stage, while the mechanism and thermdata files are processed correctrly using Chem.exe, the transport file is not processed properly.
chem.out file is created successfully, but the trans.out file is created without any content inside.
when I use the GUI for pre-processing, it is processed succesfully.
I would like to resolve this issue using the CMD prompt.
Can you provide a sloution for this?
August 1, 2024 at 12:18 pm
SVV
Ansys EmployeeHi,
Could you please elaborate the issue you are facing with the transport file. Can you please share the error message you are getting. I assume the files are available in the working directly.
- The topic ‘When running Chemkin in the CMD prompt, errors during the pre-processing stage.’ is closed to new replies.
