September 1, 2023 at 8:59 am
September 4, 2023 at 1:32 pm
Ashish Khemka
Forum ModeratorHi,
Did you try using the suggested modification?
Ashish Kumar
September 4, 2023 at 1:40 pm
xiaolong ding
SubscriberThanks for your reply,
 Yes, I have suggested increasing or decreasing the Boolean tolerance. However, no matter how you do it, you will still get an error, and the code will run very slowly when the tolerance is relaxed to a certain extent. I found an example on Github where I reported the same error, but it was caused by a small area minus a large area causing the return value to be null. But I'm constantly cycling with boolean operations subtracting small areas from large areas, which shouldn't be his kind of problem. By the way, this error doesn't start in my code's for loop, but halfway through.
Xiaolong Ding
September 11, 2023 at 3:34 pm
mrife
Ansys EmployeeHi @xiaolong Please see the Mechanical APDL Help manual on Modeling & Meshing. There is a section that discusses topological degeneracy with images of some situations that can cause them. Not all can be solved by changing the BTOL. With these you'll need to rethink the modeling steps. Â
- The topic ‘When I use MAPDL, I get an error’ is closed to new replies.
5944
1307
