July 31, 2020 at 1:13 pm
Karthik Remella
AdministratorHello Experts,
When can I say my nozzle is 'choked'?
Thank you.
July 31, 2020 at 1:14 pm
Keyur Kanade
Ansys EmployeeHello,
Choked flow typically occurs in a compressible gas flow through a Venturi tube (CD nozzle). For a fixed upstream pressure, as the downstream pressure is reduced, the mass flow rate at the throat of the CD nozzle increases. However, upon reaching a limit, a further decrease in the downstream conditions does not increase the mas flow rate of the fluid at the throat. This condition is referred to as a choked flow. The mass flow rate is dependent only on the upstream conditions as well as the density of the gas and does not depend on the downstream conditions.
Thanks.
- The topic ‘When can I say my nozzle is ‘choked’?’ is closed to new replies.
Ansys Innovation Space
- affinity not set
1414
1220
1118
1015
