October 22, 2021 at 9:41 pm
mslowly
SubscriberHello!
I am a mid-beginner in Ansys. I want to simulate wheel - rail contact in order to get results of pressure in contact path. I want to simulate wheel rotation with creepage forces. Additonaly I want to simulate slip (creepage) beetwen wheel and rail by moving rail towards wheel.
In order to make a good simulation, I want to gain knowledge and experience from you, so I have following questions:
- in which environment should I simulate- Transient or Explicit Dynamics or LS Dyna?
- should I make a contact between wheel and rail in CAD or by Ansys contact settings by chosing faces, edges, etc.?
- how to deal with contact phenomenon? Is it necessary to use APDL commands? The wheel-rail contact is highly compliaced issue...
I would be very thankful for your help :)
Best regards,
Martin
October 25, 2021 at 1:42 pmRam Gopisetti
Ansys Employeecheck the following link for an initial idea on how you can simulate an wheel and bump and from here you can start to build your rail wheel model.
Cheers, Ram
Viewing 1 reply thread- The topic ‘Wheel-rail contact in Ansys’ is closed to new replies.
4522
1494
1386
1209
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
