November 15, 2023 at 8:35 am
Yu-Han Huang
SubscriberHello everyone,
I want to use the Fluent Setup section to set up a wave height meter to measure the water level in each cabin.
The picture below is a cross-section of my boat.
The DB2 cabin will be flooded by water.
Before water enters the cabin, it is filled with air.
The steps of the method I currently use are as follows:
Setp1.After entering Setup, I created an Iso-surface in the cabin of DB1.
Setp2.On top of the Iso-surface I already created, I made another Iso-surface.
Setp3.I create an Iso-clip on the Iso-surface in the z-Coordinate.(The phase needs to be changed to water. Min=0.5~Max=1)
The method I used did not record the water level changes in the report.
Can you suggest any other ways to resolve this problem?
Thanks????
November 21, 2023 at 11:19 am
Forum ModeratorPlease can you post images showing what's going on with the flow? Also, what are you reporting on the final surface?Â
November 21, 2023 at 1:37 pm
November 21, 2023 at 2:06 pm
Forum ModeratorWhat is the domain that you're modelling? What are you trying to report on the line?Â
- The topic ‘What steps should I take to set up a wave height meter in Fluent?’ is closed to new replies.
