June 3, 2020 at 8:05 pm
ashishchache
SubscriberÂ
I am doing a static structural analysis of plastic hinge. I am new to ansys I do not know should I use contact or revolute joint between pin and hinge leaf .
AlsoÂ
1) is it good to use both at same place ( frictional contact and revolute joint) what do you think ?
2) how torsional stiffness and torsional damping value useful to that joint ? (Are they necessary to use )
When i use frictional catact between two leafs & right leaf and steel pin, and boned contact between left leaf and pin.????
Equivalent (von misses ) stress
When I used a fixed joint between left leaf and pin , revolute joint bet right leaf and pin and frictional contact between both leafs of hinge.????
Equivalent (von misses)stress
why a value of equivalent stress increased when I used joints or decreased when I used contacts ?
- The topic ‘What should I use contact or joint’ is closed to new replies.
2979
970
857
755
599
