June 30, 2022 at 10:50 am
ik356
SubscriberHi all,I have modeled an arch (BEAM188) which ends are supported by springs(COMBIN14). The arch is modeled between key points K#1 & K#2. One spring is connected between the key points K#1 & K#3 and the other spring is connected between the key points K#2 & K#4. The Uniform distribution of unit compressive pressure is applied on arch in the radial direction. Now the total system is the Global cylindrical system. K#1 & K#2 are constrained in all DOFs except in radial direction and K#3 & K#4 are constrained in all DOFs.Eigenvalue buckling analysis has been done in ANSYS APDL. The buckling shape(blue line) is shown in the below figure.
I don't want the displacement at the key points K#1 & K#2 for creating the physical model of the system.It means the effect of the stiffness value of spring should be considered without any displacement at the key points K#1 & K#2.What should be done to avoid the compression and stretching of the spring displacements at key points K#1 and K#2 ?Kindly, someone can help me by adding the effect of the stiffness value of spring without getting any displacements at the keypoints K#1 & K#2.Thanks & Regards -
July 26, 2022 at 9:37 pm
Sheldon Imaoka
Ansys EmployeeHi,
When you mention the following:
I don't want the displacement at the key points K#1 & K#2 for creating the physical model of the system.ÂIt means the effect of the stiffness value of spring should be considered without any displacement at the key points K#1 & K#2. Âcould you provide more clarification? If you don't want displacement at points K1 and K2, then you wouldn't want to use a spring since a spring does have some movement.
Is your COMBIN14 defined as a 3D longitudinal spring, or is it defined as a 1D spring (spring acting only in 1 direction, such as radial direction if nodal coordinate systems on both ends are oriented correctly)? What is your spring stiffness?
If you don't want compression/stretching of the springs at K1 and K2, why do you have a spring defined? Why not just constrain the nodes radially?
SheldonÂ
- The topic ‘What should be done to control the displacement of spring in Buckling analysis?’ is closed to new replies.
