What is the simplest way to merge the coincident nodes of two differenet lines i
    • Mehdi Baghaee
      What is the simplest way to merge the coincident nodes of two differenet lines in APDL.
      Note: these nodes are generated during meshing, so the number of them are varying but the locations are same.
      e.g.
      Line1: Node_1=(0,0,0), Node_2=(0,0,1), Node_3=(0,0,2), ..., Node_N=(0,0,N-1)
      Line2: Node_N+1=(0,0,0), Node_N+2=(0,0,1), Node_N+3=(0,0,2), ..., Node_2N=(0,0,N-1)
    • ErKo
      Hi
      The NUMMRG, Label, TOLER, GTOLER, Action, Switch
      Command can merge nodes - see help manual for more info.
      Erik
  • The topic ‘What is the simplest way to merge the coincident nodes of two differenet lines i’ is closed to new replies.
