May 7, 2020 at 5:07 am
sarathmail63
SubscriberI want to know that the purpose of Ansys Aim
May 8, 2020 at 1:30 am
Karthik Remella
AdministratorHello,Â
Up to 80 percent of the cost of a product’s development is determined by the decisions you make early in the design process. Ansys Aim is a tool that is most useful for designers to make these design decisions. Integrated geometry modeling based on Ansys Discovery SpaceClaim technology helps create 3D concept models or edit/repair existing geometry. Whether a simulation includes electromagnetics, thermal, structures, or fluids, all aspects of the simulation workflow are included in the single-window design.
Please watch these videos and you should be able to get a good overview of what Ansys AIM is capable of.
https://youtu.be/01GrgcE_ZpI
https://youtu.be/vbA-Tw94AkM
Best,
KarthikÂ
May 8, 2020 at 5:11 am
sarathmail63
SubscriberThanks for your response, I would like to know simulation difference between Ansys Electromagnetics,Mechanical and AIM. If we are simulating an object field flow etc the same object we can simulate in Ansys Mechanical work bench & Electomagnetics so what is the advantage of simulation in AIM?
May 15, 2020 at 12:18 pm
Karthik Remella
AdministratorHello,
Ansys Mechanical, Maxwell, Fluent are our high-fidelity flagship tools. Ansys AIM is a simulation tool for every engineer. It is a complete solution for design engineering simulations, which integrates all steps from geometry creation to optimization in a single environment. Also, it is a very good place of entry into the world of multiphysics simulations. Here you should be able to create templates and task-based workflows to enable non-experts to rapidly learn the software and obtain results quickly.
I hope this clarifies the difference.
Thanks.
- The topic ‘What is the purpose of Ansys AIM’ is closed to new replies.
3712
1313
1163
1090
1014
