TAGGED: ansys-cfd, mesh-quality, meshing, orthogonal-quality, skewness
December 10, 2023 at 6:48 pm
hasan.mustafa.moayad
SubscriberHi, I'm confused regarding the choice of mesh metric that can be used to check the mesh quality?? which metric can give a good representation of mesh quality, is it the skewness or orthogonal? I read some comments provided by the ANSYS community and they mentioned that the min. orthogonal greater than 0.1 will be acceptable. For me, I deal with CFD Fluent and I need to know:
1) which mesh metric I can use skewness or orthogonal?
3) To which value should I look for checking the quality, (the Min., Max., or Avg.) values of these metrics (i.e. skewness and orthogonal)?
2) what is the range of skewness and orthogonal to be defined as (accepted/good/ very good) quality?
December 11, 2023 at 8:17 am
Keyur Kanade
Ansys EmployeeFor Fluent the min orthogonal quality should be above 0.1 to proceed to solver. If it is less than 0.1 then please improve the mesh.Â
First check the locations of the bad elements. Please see following video for the same.ÂPlease go through help manual for more detailsÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
December 12, 2023 at 12:09 pm
Forum ModeratorLooks like the Forum gremlins are out to play again, /forum/forums/topic/what-is-the-good-mesh-quality-skewness-orthogonal/Â so I'll close this thread.Â
- The topic ‘What is the good mesh quality (skewness, orthogonal)?’ is closed to new replies.
3572
1188
1076
1063
952
