May 15, 2020 at 9:22 am
OscarEspinosa95
SubscriberHello, I'm trying to generate a file in Matlab that could be readed in MAPDL. I encountered with the next situation.
When I'm trying to stablish the contact between elements I noticed that the the value for the field 8 - the element shape flag its negative when its a target or a contact elements.
I noticed that in the case of the four-nodes elements the value of the element shape flag its the opposite value of ID's element that contains the sames nodes.
In the case of the one-node element, the value is the opposite value ID's element that contain that node. I can't figure out exactly to which element have correspondance, since not only one, but also some other element share the same node.
But this affects in some way at the generation of the mesh? What for its needed?
Thank you.
Oscar Espinosa
May 18, 2020 at 6:27 am
Aniket
Forum ModeratorAnsys staff can not download attachments on the student portal, so if you want to reach a larger audience to get answers from, please insert the images of the error that you get inline.
-Aniket
How to show full resolution image
How to use Google to search within Ansys Student Community
- The topic ‘What is the element shape flag?’ is closed to new replies.
2863
970
851
599
591
