November 19, 2020 at 9:46 am
ChiaraCarlone
SubscriberNovember 19, 2020 at 12:31 pmRob
Forum ModeratorNot all values are exported from Fluent to CFD Post, as Fluent is the solver some values are recalculated as needed rather than stored. If you look in the User's Guide there's a chapter covering all the definitions, which should explain what each means (I don't know without looking if they're different or not). nNovember 19, 2020 at 12:34 pmDrAmine
Ansys EmployeeIf you want things for CFD-Post please issue the Export from File>Export and choose CDAT file. All other ways are generally not helpful.nViewing 2 reply threads- The topic ‘What is the different between Wall Shear and Wall Shear Stress in Fluent?’ is closed to new replies.
