July 31, 2020 at 1:45 pm
Keyur Kanade
Ansys EmployeeWhat is tensile strength of a material? How is it calculated?
Pankaj Rajput
AdministratorTensile strength, also known as ultimate strength, is the capacity of a material to resist tensile loads without fracture. Experiments are performed to determine tensile strength of a material.
Keyur Kanade
Ansys EmployeeSo how is tensile strength related to yielding of a material? Does a material start yielding when the stress in it increases beyond tensile strength?
July 31, 2020 at 1:46 pm
Karthik Remella
AdministratorYielding or plastic deformation begins when stress in a material exceeds its "yield stress" which is different from tensile strength. The yield stress is smaller than the tensile strength (though it may be close for brittle materials which do not undergo significant plastic deformation before fracture). When stress in material exceeds yield stress, it deforms plastically but it won't fracture yet. When the stress increases further and exceeds the tensile strength, then fracture will occur i.e. a crack might propagate and the material will break into two or more parts.
May 21, 2021 at 12:44 pm
David Mercier
Ansys Employee.
To learn more about such mechanical properties, have a look into the Learn resource of the Ansys Granta EduPack software or lecture units in Ansys Education Resources:
http://support.grantadesign.com/resources/grantaedupack/2021R1/learn/
https://www.ansys.com/academic/educators/education-resources/lecture-stresses-strains-discovery
Viewing 4 reply threads
- The topic ‘What is tensile strength of a material? How is it calculated?’ is closed to new replies.
1467
