September 27, 2017 at 11:19 am
admin
Ansys EmployeeWhat is meant by Warning: Flow boundary zone 18 is adjacent to a solid zone?
October 17, 2017 at 7:46 am
Arun Kumar
SubscriberThis warning indicates that a flow related boundary (such as inlet) is in a Solid zone (Solid zone will not be solved). To correct this problem, check the indicated boundary in the message at the Boundary Conditions panel. In the example in the title, it will be at ID 18. Fix as the appropriate boundary in the Solid zone. Alternatively, the range of the Solid zone can be checked.
- The topic ‘What is meant by Warning: Flow boundary zone 18 is adjacent to a solid zone?’ is closed to new replies.
